Ubiquiti Edgerouter Wireguard VPN
If your vendor isn't listed discussion for that goes here. If we get a lot of discussion on it we will create a sub and move posts.
Bunch of links regarding wireguard VPN on Ubiquiti Edgerouter. https://www.reddit.com/r/Ubiquiti/comme ... rce_links/
EdgeRouter WireGuard Resource Links
EdgeRouter WireGuard community thread:
https://community.ui.com/questions/Rele ... c9d9c22311
Original ER WG GitHub (no longer active)
https://github.com/Lochnair/vyatta-wireguard/releases
Current active ER WG FossoresLP fork from Lochnair
https://github.com/FossoresLP/vyatta-wireguard
EdgeRouter WireGuard install/update/remove script (uses new FossoresLP fork)
https://github.com/mafredri/vyatta-wireguard-installer
ER script to automate adding WireGuard peers
https://www.reddit.com/r/WireGuard/comm ... _peers_on/
Link to ER/WireGuard/mullvad config discussion
https://www.reddit.com/r/Ubiquiti/comme ... p_for_erx/
Detailed Blog on ER/WG Setup example (note: points to older Lochnair GitHub)
https://www.erianna.com/wireguard-ubiquity-edgeos/
So not mainstream enough for production IMO but someone might easily play with this.
